We are having a problem with our bedroom slide on our 2006 KZ Escalade. When the slide is closed, it is down about 1/4" on the outside. We took it into the local RV shop and they said the problem is...
The cracks, about 8 ", are only at the outside end of the slides. Looks like something caused the crack when the side was in. When the slide is out, the underside where the roller is just fine. I found that Redwood uses metal under their slides...
