We are having a problem with our bedroom slide on our 2006 KZ Escalade. When the slide is closed, it is down about 1/4" on the outside. We took it into the local RV shop and they said the problem is...
KZ will do the work for $1k - flat rate. Now all we have to do is travel there this spring. Marty said the sheet of metal is a good idea to make it last until we can get the real fix. KZ has used metal on some slides in the past, so it is a common way to deal with the slide flooring.
