Have any of you replaced the top sweep seal or any seals on your slide(s)? I've watched a few videos and it doesn't seem to difficult but wanted to see if anyone had first hand experience. Tha...
I have, but there are numerous different configurations of seals. Mine is a "P" seal with red 3M adhesive tape on it. The hotter the wall gets, the tighter the seal adheres. Probably the most labor intensive job was cleaning the area where the previous seal was glued. Some seals fit in a channel, then some go in a channel with "fingers" that hold the seal. Between removing the old adhesive and working off a ladder, it wasn't too bad.
