Have any of you replaced the top sweep seal or any seals on your slide(s)? I've watched a few videos and it doesn't seem to difficult but wanted to see if anyone had first hand experience. Tha...
If it is actually the wiper you are replacing, some are glued with adhesive tape like mentioned above, and some are stapled also. My wipers are stapled, and have a rail to insert/slide in a D-bulb seal, which compresses with slide closed. I have replaced my upper D-bulb seal, which was very easy to do. It has a screw just a half inch inside the bulb, on each end to keep it from moving.
