The question is does anyone put stands or any supports under the slide out when parked for extended period of time or is this a NoNo. And if you do what do you use. Thanks
Try this, set your trailer up and put supports under a slide. Then let the air out of one of the tires like it went flat and see what kind of damage happens to the slide.
