The question is does anyone put stands or any supports under the slide out when parked for extended period of time or is this a NoNo. And if you do what do you use. Thanks
if your slide outs require support the factory would have shipped the TT with supports. if you use 2x4's or the like under the slide out and your tires go flat over night while you are sleeping, you would have to buy new slide outs
