Imaroadrunnr
Aug 01, 2013Explorer
Slide trouble still
I have a 2001 Cedar Creek 34 footer and pull it with a 2005 Dodge Cummins/6 speed long bed 4WD and recently the main room slide would continue to try to close the slide after it was all the way in. The motor would stop and then start working for about 3 seconds and then stop and then do it again. When I got back from my trip to Utah, I noticed the kitchen slide was doing the same thing then the bedroom slide did it also. My question: Have you had any trouble with your slides? I have lubricated the slides and replaced the circuit breakers and topped off the oil reservoir with no change. I am thinking that the switch has some crud in it as when the slides start going in they don't stop when the rocker switch is released. Maybe I should blow it out with compressed air. Funny that there isn't any trouble when the slides are coming out. Hmmmm.
Thanks in advance,
Thanks in advance,
