Txsurfer's avatar
Txsurfer
Slide usage while making pit stops..
We are looking at toy hauler 5r's and one thing that bothers me are the floor plans that require you to open a slide or two to access the bathroom. It seems that there are very few floor plans that meet all our criteria so something is going to have to give - momma wants a wardrobe slide and I suspect she will get it.
We generally like to use "own" bathroom while on the road.
Having never had a rig with slides - is it a PIA to open and close the slides just to take a leak? does the rig need to level to run the slides in/out?
  • It may be best to find a floorplan that allows bathroom access sans slides. If not, you may not have to deploy the slide all the way. I find it's best to be level.
  • Do not know about toy haulers but my 5er can push the slide out some, without being level front to back or side to side. I have never tried to take it all the way out, if I am not close to level (within a few inches). Hooked up and parked on reasonably level ground I can put the slide out. I travel a little nose high but at the slides location the front to rear difference is very small.
    I use the RV toilet but only if I am not going inside a fuel station for some other reason. The wife almost always prefers the station facilities, but that is because she does not like to deploy the RV steps. If I put out the steps or no other option is available, she will use the RV on the side of the road---I will use a bush if one is easier to access than the RV ;)
    BTW: we can access everything in the RV with the slide in. I know that some cannot.
  • one reason I don,t like slides,another is a lot of them leak. or have in,out problems. I can ruff it a bit and not have any.
