joelc
Jul 01, 2017Nomad
Slideout seal repair
Not sure if this post is in the proper place.
I have a 5er and on one of the slide outs the top seal is cracked in the corner and starting to tear. The remainder of the seal is fine, including the inner seal. Is there a way to patch this area so it won't tear further. I thought of a inner tube patch, but I want some input before I do it. The area does flex quite a bit when the slide goes in and out, so I think Eternabond Tape might be too stiff. I also thought of a silicone bead over it, but not sure.
You're inputs would be appreciated.
