- wanderingaimlesExplorerA good dose of bleach works.
- Retired_JSOExplorer IIYou can fill the tank all you want but they will retreat to the vent pipe until the water subsides. They are in every sewer system, even your s&b home. Worse when a septic system or in your case a holding tank is their abode. I get a few sometimes.
- LwiddisNomad IIIAFTER the bug killer ScottG suggested. “Then I’d...”
- winnimanExplorer IIDo you leave your black tank flush valve open when hooked to campsite services?
- philhExplorer IIIsewer flies. PITA little things
- ScottGNomadSome tanks, like mine, have an area in them that never gets flooded even when full. It can be a high spot in a corner caused by the top of the tank sagging slightly. On mine, they chose to put the "full" sensor in one of those corners so my tank level gauge will never read "full". The little bugs probably concentrate in a spot like that.
- Jerry_BExplorerI did fill the blackwater tank completely full once and flushed. Didn't do the job. I'll try it again and spray raid or something into the tank. Thanks.
- LwiddisNomad IIIThen I’d fill completely and flush...twice. Completely.
- ScottGNomadOpen valve, spray your favorite aerosol bug killer into the tank for 5~10 seconds. Close valve and let sit.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
