- bshpilotExplorerIm curious - those of you that are having problems, are you keeping water in the toilet bowl all the time ?
I fine that if i keep water in the bowl (above the seal) that i rarely have a problem. Even when in storage i keep the seal wet by making sure theres some water in the bowl - doesnt have to be much....just enough keep the seal wet. - happy-2ExplorerIT works better if you clean the seal then apply some vas aline on the seal,and work it . it fixed mine
- J-RoosterExplorer
hershey wrote:
I'll give this a try!
Please try the vinegar treatment. It absolutely works. Make sure that there isn't any paper stuck to any part of the ball or gasket. Calcium will disolve easily with vinegar. - J-RoosterExplorer
ScottG wrote:
X-2, Mine is the same way Scott!
My SeaLand only holds water about half the time. Make no difference to me - it doesn't smell or anything when it leaks out. - KoopExplorerOur Thetford will fail to hold water occasionally. I add an ounce or two of vegetable oil to the bowl and it works itself out after a day or two. We full time, I also add vegetable oil when we're driving down the road. I started doing this after having a chronic problem that seemed un-fixable. Works for us.
- gwheelExplorerI have a sealand, and it would not hold water, but it had been setting for about 4 years, and this is a 2003 mh. I pulled the top off, and removed both rubber seals and cleaned them with dish liquid, and scrubbed the ball, but back together and it has been working perfectly for about two months. Geo
- hersheyExplorerPlease try the vinegar treatment. It absolutely works. Make sure that there isn't any paper stuck to any part of the ball or gasket. Calcium will disolve easily with vinegar.
- CG_DawsonExplorerI have used the same product that bshpilot mentioned, Thetford's Toilet Seal, it really does work.
- BB_TXNomad
ferndaleflyer wrote:
I won't be replacing this ceramic toilet that looks better than the ones in our house.....I think it might be a Thetford but not sure....I just looked through all the paper work and the pull out dump deal is that brand but it don't say what the throne is.
Mine has a tag on the lower back side. Had to lean over with my head down behind to read the name and model number. - Dune_HaulerExplorerFunny enough my 3 year old Thetford Style Plus just stopped holding water. I tried all the tricks I read online with no luck, gave up and bought the 34117 repair kit. The seal has some sort of Teflon lining I think they just give up after a while. Good luck with yours.
