rdmotex3
Dec 07, 2020Explorer
So Lost
Hello all I have read,and read, and read but it seems you can slice the argument whatever way fits your setup best. I just signed docs on a Reflection 367 and am waiting to set up an appointment for t...
Lynnmor wrote:Cummins12V98 wrote:
My factory air bags are basically what supports my 6,000# pin and 9,750# RAW.
Your suspension is quite a bit different than a leaf spring setup with added aftermarket air bags. The leaf springs control not only vertical loads, but helps with side to side as well. Replacing soft leaf springs with stiffer helps a bit with control in all directions. I use air bags to restore height but I would change the leaves if a considerable amount of additional support is needed.
