Sam Spade wrote:
D.E.Bishop wrote:
We now have the Winnie and it does have the disconnect and I have the some draws but haven't had the inclination to check how much.
It doesn't really matter how much; the battery disconnect switch should eliminate ALL of them.
Your battery tender, whatever kind it is, should be wired to a point at or very near to the battery where it will NOT be disconnected by the switch.
IF....it appears that your batteries are losing charge with the switch in the disconnect position, then either your batteries are going bad or something is mis-wired.
My solar battery minder is wired directly to the batteries and even with the disconnect activated there are parasitic draws such as the CO detector and outside entertainment center. I have not and do not care at this point as since I performed a full battery maintenance, inspection and cleaning, I have full charge when I park it in storage and full charge when I return to prep it for a trip.
I do have some background in battery maintenance from my Navel career. We had two batteries on my boat and they were capable of putting our 1500 amps for a considerable period of time. While I was not an electrician in the Navy we all at one time or another had to clean and inspect the 526 cell battery occasionally. Batteries that big do have a certain leakage due to condensation from gas off and the atmosphere. To minimize that, we had to wipe down the cell tops and all connectors, that is where I learned that sulfuric acid does not effect wool cloth.
