Drought_Buster
May 25, 2014Explorer
Yeah, the battery disconnect is in the right position. When it is off, there is absolutely no power to 12 volt. This is the first thing I checked to figure out that the battery wis wired wrong. When I switched that all the 12 volt went out. Put it back and the lights came back on. I do not hear a hum, but do not recall ever hearing one. I can't seem to locate the inverter. I did flip the breaker labeled "converter", but nothing happened. None of the little lights that come on to indicate a blown fuse is lit. I changed the fuses that are in the lines inside the battery compartment even though I have no idea what they go to. If I can find the inverter, I am hoping it has fuses on it that I can try changing. I have a Montana High Country DBRS. Any idea where my inverter is??
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
