hmknightnc
May 25, 2014Explorer
Drought Buster wrote:
Mini breakthrough. I flipped the breaker labeled "converter" and heard what sounded like a fan come on. It stayed on for about three seconds then went off. I flipped the breaker, waiter thirty seconds, flipped the breaker back on and, again, a fan or hum for three seconds and it went off. So it sounds like it wants to start but can't for some reason. The problem is I can't find the dumb converter to take a look at it.
It's probably behind a panel right below those breakers. Find it and replace it, also check those reverse polarity fusses since you hooked the batteries wrong
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
