walker111's avatar
walker111
space heaters
Saw the other similar post but I am actually asking about space heaters for the garage. I have 2 boys aged 12 and 9 and a 12 foot garage in my 2014 Voltage with one heat vent. Have not camped with it yet but know it will get cold.
What heaters are you guys using for electric space heaters?
Thanks
  • The oil filled heaters and the cube heaters do a good job.
    Take your pick. Around kids I would chose the oil filled radiator. ;)
  • Just a little cube heater from Walmart. It has a very quiet fan.
    A lot of people like the oil-filled radiator type. Check the current load to make sure you won't blow fuses.
    Just make sure anything you get has a tip-over cut-off switch, and teach your boys NOT to lay things on it, and where it needs to go.
  • I like these when kids around but they do take up some space. With a garage it shouldn't be a problem.
    http://www.homedepot.com/p/Cuori-1500-Watt-Electric-Oil-Filled-Radiant-Portable-Heater-Grey-HD904-A7Q/205210318
