klr650goldwing
Jan 21, 2019Explorer
SRW vs DRW
Is there a general rule regarding how much weight is okay for SRW and how much is too much? We are thinking of a larger 5er and not sure how much larger will require a new truck too.
twodownzero wrote:ependydad wrote:
So, ignoring legalities for a moment - my buddy bought a new trailer and was pulling it with his SRW 2014 Ram.
When he took it to the scales, he found he was over on GVWR and GAWR but most importantly, over on the tire load capacity of the stock tires on the truck. Here's a full write-up with weight slips (you shouldn't need to sign in):
https://www.facebook.com/LearnToRV/posts/1961335943933816
I'd think that people who are possibly running overloaded should make sure they're not over on the tire's capacity. IMO, that's the weakest spot.
It looks like he's towing 17,000 lbs. with a SRW truck, of course he's going to be WAY overloaded.
4x4ord wrote:
Exactly. You would need to be grossly overloaded before most police officers would bat an eye. Then your GVWR would be used as the mark to guage by.
He is over on everything that matters! TIRES!!!
That is so wrong!!!
The weakest link!!
4x4ord wrote:
How British Columbia views weight ratings.
Basically:
What are the penalties for driving a
vehicle loaded above its GVWR?
Regulations in BC were recently changed to
address consumer and industry concerns about
the GVWR. If a vehicle, with a GVWR of
5,500 kilograms (kgs), or less, that is
manufactured before January 1, 2001 is loaded in
excess of its GVWR and enforcement officer
deems it to be unsafe, the driver of that vehicle
may be given a Notice and Order. Most light
trucks and RVs have a GVWR of less than
5,500 kgs. If a vehicle with a GVWR of more than
5,500 kgs, regardless of the date it is
manufactured, is loaded in excess of its GVWR,
the driver of that vehicle may be given a violation
ticket. Driving a vehicle loaded above its GVWR
creates a potential safety hazard because the
vehicle’s frame, suspension, brakes and tires are
not designed for weights above the rating the
manufacturer has set.
