Dayle1
May 29, 2014Explorer II
Most LTs are NOT made in China. Switching from STs to LTs has several issues. There are almost no identical sizes, so you will need to confirm have sufficient width or height clearance for the LTs. Also, as long as you have 5200 lb or 6000 lb axles, then load capacity is not an issue as most LTs in load range E have a 3042 lb capacity. However, 7000 lb axles may require load range G tires.
I had Maxxis ST tires on my last fiver and had serious problems, switched to LTs, BFG Commercial T/As.
About Fifth Wheel Group
