JIMNLIN
May 29, 2014Explorer III
op asks wrote:
Any problems with appropriate Maxxis on a 5'er?
Many folks use the Maxxis ST8008 and some use the commercial grade Maxxis U-168 LT tires on their trailers. The Maxxis ST is not without reported problems on this website. However the ST8008 are popular on this website and not so popular on other trailering websites.
Any problems with putting LT's on a 5'er rather than ST's?
Assuming the owner uses a LT with enough load capacity and one that has been recommended the owner will generally see more service miles and much more reliability. Before the tire industry gave us the ST tire everything was P or LT tires (passenger/light truck tires).
What LT brands are not made in China? Are there any that are specifically manufactured in the USA?
We have several usa brand LTs available however the problem isn't just made in china. We've had the same issues with ST tires when they were all made in the USA. The problem is the ST tire design/performance.
There are some very good LT and multi position tires not made in the USA so it all depends on the size tires your needing. Some of the smaller 5ers come with 15" and go up to 17.5" tires and wheels on the larger trailers.
Your queston is pretty general so give us your trailers GVWR/axle ratings/current tire size and load range and we can give you some very good advice on a particular tire size and brands.
About Fifth Wheel Group
