wandering1
Jun 01, 2014Explorer
Dayle1 wrote:
Most LTs are NOT made in China. Switching from STs to LTs has several issues. There are almost no identical sizes, so you will need to confirm have sufficient width or height clearance for the LTs. Also, as long as you have 5200 lb or 6000 lb axles, then load capacity is not an issue as most LTs in load range E have a 3042 lb capacity. However, 7000 lb axles may require load range G tires.
I had Maxxis ST tires on my last fiver and had serious problems, switched to LTs, BFG Commercial T/As.
Sounds like you have your axle weights mixed up with tire capacity. Axles have nothing to do with tire capacity. Tire capacity has to be enough to handle the weight of the trailer which includes the weight of the axles. The weight capacity of the axles has to be enough to handle the weight of the trailer which does not include the tires.
I am sure the RV manufacturer put the right axles on the trailer, focus on tire capacity to handle at a minimum the weight of the trailer less the king pin weight.
About Fifth Wheel Group
