gmw_photos
Jun 02, 2014Explorer
Me Again wrote:bobx2 wrote:gmw photos wrote:ol Bombero-JC wrote:
If you have 15" wheels, your choices are limited. Look to Maxxis.
If you have 16" wheels - Michelin XPS Ribs or BFG TAs (also Michelin) will be an x'lnt choice.
In 15" there are several LT commercial tires available if you want to get away from ST
Care to share where you found several LT tires in a 15" size? And what their load ratings are? Pretty much have to go with ST tires in the 15" size if you are carrying any weight at all. Carlisle and Maxxis are all I'd consider.
LT225/70R15 tires Goodyear Cargo G 26 and Continental Vanco both are rated at 2450 # weight.
Chris
Thanks Chris, you beat me to it. I am also seeing the Nexen tires being mentioned here and there. The Roadian HT LTV seems to be available in 15" from walmart. It appears to be a load range C. For a 235/75-15 ( 1984 pounds ) it specs a 6.5" rim, so a person needs to know about their wheels also.
As a 215/75-15 ( 1764 pounds ) it specs a 6" rim.
EDIT: I would likely choose the GY G26 though, before I would choose the Nexen. I just throw the Nexen into the mix as something to consider
About Fifth Wheel Group
