Me_Again
Jun 03, 2014Explorer III
Lowsuv, the other thing you fail to point out is the even with the GY ST235/80R16E having a retain price of $135, the trailer manufacturers buy ST tires and wheels pre-mounted from Tredit or Tireco for dimes on the dollar of these retail prices. My guess would be that an aluminum wheel and ST 16" tire goes for around a hundred bucks each or less for a semi trailer or train car full of them.
If one goes 10 miles once a year to the lake, they will last quite a few years. Want to see America and you better be really lucky or install quality tires.
I made a similar weight comparison back in 2009. http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/23161726/srt/pa/pging/1/page/1.cfm
Some of our tire industry insiders claim that there is not that much difference between the construction of a ST tire and a LT tire. And my response to that is why do we keep getting tire tread after tire tread about failed ST tires. Not just here but across the web. The fact that Power King and Carlisle are both trying to improve their tire design speaks volumes on the subject. Yet this latest addition of a Nylon overlay was added to the GY Marathon years ago. So I hold little hope that the new TowMax and Radial RH are the fix all.
The basic problem as you point out and I have on many occasions is that we have lightweight over rated tires that just are not up to the job for large RV trailers. Most of these tires have a tread pattern that looks like an All Season tire, which is OK on a single axle trailer, but may add to the problems on a dual or tri-axle trailer.
A good trailer tire will have a out rib with not brakes in it to grab the pavement is tight maneuvers. This new tire that Tredit is importing has a better looking tread for a ST tire than others I have seen. However we see reports of early failures on them. So it is more than jus tthe tread pattern on cheap ST tires.
Here are the GY Marathon, TowMax, and Freestar tread for comparison.
Now take a look at the Sailun LRG, which looks more like the G614 GY, XPS Rib and R250!
Chris
Chris
About Fifth Wheel Group
