Me_Again
Jun 03, 2014Explorer III
laknox wrote:
FYI, my FW has a GVW of 11,300 lbs, and has a fairly light pin wt. For D-range tires, I'm nearly at the limit of their capacity. I ended up going with E-range Carlisles this last time because I couldn't wait for Discount to ship in the Maxxis I really wanted. So now, tell me how many E-range 15" tires you can find, ST =or= LT? NONE in LT and very, very few in ST. FWIW, even Maxxis are simply up-rated D-range LT-type tires, IMO. With the prevalence of "light" or "1/2 ton" TTs and FWs these days, all running 15" wheels, you'd think even ONE tire company would grab the bull by the horns and make a =good= ST. We certainly know the bean counters who never leave their offices at the RV manufacturers won't demand it.
Lyle
That is strange NADA must have their data all screwed up!
http://www.nadaguides.com/rvs/2004/Used/Komfort
And another
http://66.111.103.196/Navigation.do?product=RVBB&yearId=2004&year=2004&manufacturerId=1467&manufacturer=KOMFORT+CORPORATION&modelId=75448&model=KOMFORT+FIFTH+WHEEL+TRAILERS
Found this:
"Lyle
Here's my data:
2004 Komfort 25FSG
UVW - 6,679 lbs
dry pin - 1,113 lbs
dry ratio - 16.66%
GVW - 11,300 lbs per the sticker
calculated pin wt @ 16.66% and full GVW - 1,882 lbs"
11300-1882=9418 on the axles fully loaded. Might be kind of hard to add that much stuff to a 29'er to get it up to GVWR with 4621 CC.
So what is the actual scaled weight on your axles?
If you are running the Carlisle at 65 lbs inflation on your D rated wheels, then you have 2540 pounds capacity. The two LT's that I noted have 2450 capacity. I think I would take one of those over a ST any day.
Chris
About Fifth Wheel Group
