sloman2001's avatar
sloman2001
ST235/80R16 Tire Replacement
I wish to go to the LT tires, and the shop I called said they do not make them in that size, I would have to go to an LT235/85R16 tire. He said since this tire is a bit larger than the old, you have to check the clearance to make sure it would fit. He claims my old rims would still work fine.
In looking at my clearances, it would appear all would be fine, both from the top and side since I have tandem axles. I have a 5 inch clearance between the tires, and 3" from above. The tires he says are about 1" larger than my current, so the above clearance would become about 2.5" rather than the 3".
Does this make sense to all of you. I am not a tire expert, or a 5th wheel expert either for that matter. I'll check with my RV manufacturer, but I know what they will say. They usually are not much help with anything.
Thanks, Tom
