BB_TX
Jan 16, 2014Nomad
I put LT 235/85 R16E on mine to replace the STs. Your numbers are correct.
But make sure your trailer weight is OK for the LTs if they are load range E. They are probably going to be rated for about 400 lbs each less than your current ST. No problem as long as your trailer weight is ok for that. Mine is.
About Fifth Wheel Group
