zell66's avatar
zell66
StableLoad Suspention Stabilizer
I purchased a 2008 F-350 crew cab 6.4l and a 2012 Forest River Sierra 365SAQ.
First off this is my first 5th wheel and diesel. I have towed for the last 20+ years, we just upgraded.
Questions:
Does anyone have a StableLoad on there truck? Pros and Cons?
torklift.com/rv/stableload#appguide
My truck has very little squat when I load 5th wheel and it is a challenge to find sweet spot to uncouple hitch. Any suggestions on how to make this process easier?
  • I tried both at same time, and despite cutting almost half the uppers off (perhaps bit more than), the uppers were still making contact all the time w/ upper aux spring-- thus making for a harsh ride empty. Removed them and replaced w/ stock rubber pads and just went w/ lowers only. Truck only dropped 2" w/ 3800 lb pin wt. Very happy w/ results.
  • Cummins12V98 wrote:
    "it is a challenge to find sweet spot to uncouple hitch"
    What hitch are using? Curt?
    I have a superglide 4100
  • "it is a challenge to find sweet spot to uncouple hitch"
  • For those of you that have used this system did you use the upper or lower overload device? or used both upper and lower?
  • Had them as well in our '15 F350 SRW and they worked as advertised by engaging the lower springs before the aux spring. Yes it did add some to a stiffer ride, but I think the tires being aired up to 80 psi made the ride worse. Purchased a long handled 3/8 ratchet and short extension and wore a old sweatshirt while engaging/disengaging them. Found out after 1st winter that they rusted up and had to make them a little looser so as to not have them do it again. With new coach, truck still came into contact w/ the aux springs, but truck dropped only couple of inches overall. Truck didn't come w/ camper pkg/swaybar, but the lower Stable loads took the worry out as truck had no sway w/ them engaged. Took them off in case I want to add to new truck, but don't know if I need them yet or not. IMO, well worth the money.
  • I have them on our 2008 GMC 3500 DRW and really like them. Only took an hour to install, no drilling needed on my truck. Takes just a couple minutes to engage them. The truck only squats an inch with them. The two areas that I had the most improvement is over bridge abutments and it eliminate my driveline chatter at launch.
  • I have the stable loads on my truck. I stopped using them because I could fill every bump on the road. They are also hard to install. I now have air bags and I like them a lot.
    If you fill you need something I suggest air bags and a Hellwig big wig sway bar.
    Questions:
    I had the stableloads on my Chevy 2500 and they worked very well. By capturing the overloads, there was very little squat. They were kind of a pain to swing them them out of the way while not towing
