Dwund's avatar
Dwund
Pleasure-Way Air Suspention leak
I am new to this and have jsut purchased a 2008 PW-Excel TS. It has an in-cab Firestone Air suspention in the back. One side does not keep the pressure. Where do I start looking and what should I do???
D
  • Does anyone know where the compresor for the "air-shocks" is located in my 2008 PW Excel/
  • Mine goes down in about 5 minutes. I get it up to 50 psi and you can actually watch the needle go down.
  • My 1997 Xplorer 230XL has rear air bags and the right side has a slow leak I live with. A panel truck ran into me in a backup and caused it. The air holds for a week or more then slowly it goes down.
  • There may be an air line or air fitting that is leaking..get under the unit with a spray bottle of soapy water & spray the lines & fittings, to look for a leak..if none is seen then you may have an air valve problem..good luck..
