LingerLonger's avatar
LingerLonger
Pleasure Way 2020 rekon
Touch screen control panel showing a fault:  "The DC Current Monitor is offline".  Any recommendations on a remedy.  Thank you
1 Reply
  • Max1's avatar
    Max1
    Explorer II
    Sounds like a glitch with your DC current monitor. First, try the basics: check all connections and fuses to make sure nothing’s loose or blown. If that doesn’t work, a system reset might help, turn off the power for a few minutes, then restart. If the issue persists, it could be a faulty sensor or control panel, and you might need to consult your manual or reach out to Pleasure Way’s customer support.
