noteven
Apr 18, 2013Explorer III
I just measured the voltage through the diode isolator that I connect to the camper batteries when it is loaded on my truck - alternator output is 15.6v, isolator output is 14.74v.
So what you guys are saying about using a diode isolator in a starting battery situation on the trailer is that the converter's charger may not have enough output to supply enough charge voltage to the starting battery through the isolator?
The portable power supply might be the simplest backup solution of all.
About Fifth Wheel Group
19,040 PostsLatest Activity: May 29, 2026
