Thermoguy wrote:
Why use a hitch that could or might cause the trailer frame to fail? Seems like you are playing Russian roulette. If I know one things about companies, they will do anything to get you to buy their product and everything to not pay a claim. So, if the frame bends and cracks, it's on you. I think I read even the Goosebox is only a warranty for 2 years. What do you do after that?
Stick with a real 5th wheel hitch. If you have a ball hitch, get one that works with that like the B&W Companion.
Anyone who makes that statement does not understand the difference between a true gooseneck hitch and the Andersen Fifth Wheel Hitch. They're making a judgment on something they have never used. If you want to know about an Andersen, ask an Andersen hitch user.
As I said in another thread and will say again; THE ANDERSEN IS NOT A GOOSENECK HITCH! ANDERSEN GOT APPROVAL FROM THE DOT AS A FIFTH WHEEL HITCH!
First; How can an Andersen cause your frame to fail? The forces at the pin are the same as a conventional fifth wheel hitch.
Second; you must be referring to the hundreds of warranty claims made by Andersen hitch users for damaged frames. Oh, my bad, there hasn't been a single one with over 30,000 Andresen hitches in use.
Here's your answer from the Andersen website:
"A few RV/Trailer Frame manufacturers have said (or implied) that they will void the warranty on their 5th Wheel (or frame) if an adapter is used for hooking up.
Officially, that is illegal. According to the FTC’s Magnuson-Moss Warranty Act they can only void the warranty if the adapter actually CAUSES damage, not simply if it is USED. Additionally they have to PROVE the damage was caused by the adapter.
Our solution:
For the Ultimate 5th Wheel Connection, if they won't cover it, please submit a claim to customerservice@anderseninc.com. We stand behind our product and with the Ultimate Connection we will cover warranties up to $5,000,000. For more info regarding this coverage, see our supplemental warranty."
B&W, Curt, Pullrite, and others all make great fifth wheel hitches and they all work. Some of us just want a different solution that's much easier to use and more convenient to take in and out of the bed of the truck.
