C-Bears
Feb 18, 2015Explorer
ksbowman wrote:
Why not put a step ladder on each side and a work plank between the ladders (above the slide roof), then you would not take a chance of damage to the roof or slide.
My manufacturer says I can walk on mine but if I recall they have a suggested weight limit of 225, which I am 5 pounds over. I probably wouldn't even if I was under.
I guess you could try to run a walk plank over the top, even though setting that up would be difficult, plus I am not sure how you would work off a plank when the work would be below you.
I suppose my first choice would be to get someone around 160 pounds to do the work. My second choice would be to set up next to the slide, but high enough off the ground I could easily lean and reach over for my work.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
