fj12ryder
Aug 30, 2021Explorer III
I'd check the bevel gear, and/or the jackscrew threads. It sounds like the bevel gear is spinning, but not transferring rotational force to the jackscrew. With enough force on the leg, it may work a little. The bevel gear pin could be sheared and/or the bevel gear teeth worn. Of course this is assuming the cross shaft is turning like it should.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
