TGO's avatar
TGO
Suburban Electric Water heater
I have a 2005 Carriage It has a Suburban Gas/electric hot water heater. Lately the electric side has been working intermittently. Very frustrating. Gas side works perfect. I replaced the element with no luck Then I took the partition out and when moving some wires around, it started for a while. Thought maybe it was a loose connection on the modulator but when I put the modulator back into place I lost power to the element again. I'm not an electrician although I do have a light knowledge and a few electronic tools to check voltage and amp. Anybody have any ideas? Question: What is the purpose of the modulator? Is it for gas, electric or both? Probably have to take it in but just wondering if anyone else has had similar issues. Thanks
  • So modulator has no connection to AC side?
  • On that model the electric is totally separate from the lp side. Electric consists of the switch on the outside, the thermostat and Eco, which is under the black plastic cover on the left side, and the element.
