ScottG
Sep 30, 2014Nomad
I would double check the cheapo power switch - which is shown in the bottom picture above in the lower left hand corner.
After that it's more likely the element itself is bad. You can verify it with a ohm meter. It should show a low resistance, if it's bad it will be open.
FWIW, I'm on my third RV with a Suburban and the present one is more than ten years old. Not one of them has ever had a problem.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
