kuziwk
Jul 03, 2019Explorer
SuperLube Axles
Hi Guys, i have a winnebago 27rls (2016 Model). Everything i read said not to use the superlube axles feature as you run the risk of getting grease on your brakes. Its been about 10 years since i ...
MFL wrote:
You will likely ruin the seal, when removing it, to access the rear bearing. It is best to replace seals. You can take the numbers off the axle placard, and call axle manufacturer, with that info. They will know what seals, by the numbers on axle, and can sell the proper ones to you, or advise where to purchase.
Also, a good bearing/seal parts supply can likely match them up. I like having the proper new ones in hand, before removal, but that's just me.
Lots of opinions on use of EZ-lube feature. I have used mine, with no issue, but have hand packed initially to know what grease is in there.
Jerry
