kuziwk
Jul 03, 2019Explorer
SuperLube Axles
Hi Guys, i have a winnebago 27rls (2016 Model). Everything i read said not to use the superlube axles feature as you run the risk of getting grease on your brakes. Its been about 10 years since i ...
kuziwk wrote:
The MFG probably made this system to make assembly cheaper and less labor intensive. They will likely not fix the brakes if there was a problem which is more expensive than a few more labor hours to pull the drums off.
