kuziwkExplorerJul 03, 2019SuperLube AxlesHi Guys, i have a winnebago 27rls (2016 Model). Everything i read said not to use the superlube axles feature as you run the risk of getting grease on your brakes. Its been about 10 years since i ...Show More
fj12ryderExplorer IIIJul 03, 2019I've had my 2010 Keystone Fuzion since new and used the EZ-Lube feature. I pulled the brakes last year and everything was fine. When you do it the first time, you'll use about 1/4 of a tube of grease to get fresh grease out the end of the axle. Not exactly a "ton of grease". But in the end it's all in what you feel comfortable with.
Related ContentGreasing LCI SuperLube AxlesBent axle.Dual axle vs triple axleAxle ServiceAxle and tire?
