kuziwk
Jul 03, 2019Explorer
SuperLube Axles
Hi Guys, i have a winnebago 27rls (2016 Model). Everything i read said not to use the superlube axles feature as you run the risk of getting grease on your brakes. Its been about 10 years since i ...
cummins2014 wrote:BB_TX wrote:
I had never heard of Super Lube Axles and had to look it up. Same principle as EZ Lube but made by Tie Down Engineering whom I have also never heard of.
I have the EZ Lube on mine, have used that lube feature several times, and have never gotten grease on my brakes. Just carefully followed Dexter guidelines.
Does there come a point where its time to pull those bearings, and clean out all that grease in there . I have been tempted at times to use the EZ lube feature, just can't bring myself to do it , after hearing the problems . I would certainly follow the guidelines if I did .
