kuziwk
Jul 03, 2019Explorer
SuperLube Axles
Hi Guys, i have a winnebago 27rls (2016 Model). Everything i read said not to use the superlube axles feature as you run the risk of getting grease on your brakes. Its been about 10 years since i ...
TxGearhead wrote:
The EZLube has a drilled spindle. It is drilled from the outboard end to the area between the grease seal and the inboard bearing, then drilled radially to the surface of the spindle. The outboard end has a grease zerk. When you pump grease through the zerk, it follows the drilled channel to the void between the seal and inboard bearing, through/around the bearing rollers, through the void in the hub between the bearings, through the outboard bearing, and you will see the older grease pushed out around the rollers of the outboard bearing.
