kuziwk
Jul 03, 2019Explorer
SuperLube Axles
Hi Guys, i have a winnebago 27rls (2016 Model). Everything i read said not to use the superlube axles feature as you run the risk of getting grease on your brakes. Its been about 10 years since i ...
kuziwk wrote:Lynnmor wrote:kuziwk wrote:
well looks like im pulling each wheel off this weekend for peace of mind, i even bought a 1" socket to torque the castle nut to 50 lbs to seat the bearings. After which i will back off and tighten finger tight. It will be a good opportunity anyways to adjust the brakes...right now my truck is at the max on the brake controller and i cant lock the trailer tires.
Actually the 50 lb figure only needs to be done when installing new bearings. After that, just a firm tightening with large pliers is sufficient. Factory instructions are written to cover all installations.
So should I just tighten them finger tight? Any harm in torquing them down and backing off?
