Whitey930's avatar
Whitey930
Sway Issues
Hi all. Hoping to get some advise regarding trucks to pull our recently purchased MXT 303 Toy Hauler. I knew we'd need a different truck to pull it with our two large motorcycles. My current 2014 F-150 goes back off lease soon and although it can pull the 6500 lb empty trailer, the bikes put it at 8000 lbs, about 1000 lbs over the truck's tow rating. We just took a 2016 F-150 Ecoboost out for a test drive today with the fully loaded trailer. This truck has the max tow package and has a tow capacity of 10600 lbs. It had no problem pulling it with rpms rarely over 3000 even up grades. The problem was the swaying of the trailer and the pull it had on the truck. Pretty severe at times as it was a windy day.
The trailer has the Reese Weight distribution system with the anti sway cam system, which is supposed to be one of the best systems out there, but I do not have the hitch head and the trunion bars that go with the system as the previous owner of the trailer must have kept them. As a result our test drive was without any weight distribution or sway management. So my question is once I get these parts and am able to hook up the system will it eliminate, or lessen the sway enough to be able to pull it with this truck? I really don't want to have to get an F-250 for the small amount of time I'll be towing this trailer. Especially with the deal I can get on this F-150.
Does anyone have experience with this system or these systems generally as to how well they work?
Sorry for the long winded post. Any help much appreciated.
Read more: http://kzfamilyforum.com/thread/1316/sway-issues#ixzz4OVqiHgQb
  • If it was me, I would head to a CAT scale to get your rig weighed. Tongue weight should be at least 10 percent (ideally 10-15 percent) of the gross weight of the trailer. If you have insufficient tongue weight, anti-sway will help. However, it's just a band-aid fix and doesn't address the root problem.
  • What tires are on the truck. Probably 'P's you'll need at least 'E's.
    P's have soft sidewalls.
  • Not enough tongue weight with 2 bikes behind the axles. My father had a Stryker 2912. We loaded 2 cruisers in the back and it jerked my 2500 all over the road until we moved the bikes over the trailer axles. It would even jerk around my father's 3500 DRW if he didn't back his RZR in over the axles.
    Anti sway sway helped for him. Said it was night and day better and it was just a friction bar.
