hammer21661's avatar
hammer21661
Talk me out of it if you can 19.5s
I am getting ready to pull the trigger on a set of Vision Hauler 81 and I think I have decided on BFG ST230 225/70r19.5 tires. I don't wanna have to remortgage the house on Michelins. If you have any better Ideas let me know. Thanks, Bill.
EDIT: Sorry guys I mean for the 5th wheel I can't get but one tire for the weight of the 5er in a 16 inch rim that doesn't have the 65 mph speed limit. the bfg st230 is a rib tire that has a 75 mph limit. Yes, I have read the posts and what not about the 19.5s in the forum. I have blown the tow max tires numerous times. Thanks,again.
  • When I when from duallies to supper singles I went to 19.5 - the 16 in wheel just can't handle the rear axle weight.
    I ended up going with the Toyo M608Z tire - very beefy, regroovable, as has been said a real MDT tire.
  • I mounted Bridgestone M895's on my F450. I've only had them for 1K miles and they haven't set yet, but they did well in the snow this winter, and they have a multi purpose type of tread. They do sing on the highway, but I don't mind that. Might be something you could consider.
    I can tell you that the selections for 19.5 tires is limited, and they are medium duty truck tires. That means they have high weight ratings, are stiff ride quality, and most are of a highway rib design. They are also expensive, if you get a quality tire. My cousin is in the tire business, and he says you definitely get what you pay for and if you read these forums, they will testify that cheap tires are generally not worth it (to me this is true). I already had the 19.5 wheels on my F450 (stock) and I didn't want to change wheels. The selections for 16 and 17 inch tires is much more flexible, and I would recommend them before the 19's. If you want bigger wheels, you might check the tire selections for 20's. There might be a wider range available for them.
  • B.F. Goodrich tires were originally made in Ohio, USA. The B.F. Goodrich brand of tires is now owned by Michelin.
