pigdoc wrote:
Thanks for the info. The trip today was heading west, from 4-8pm, with a medium headwind and outside temp 92F. Is 116F a high hub temp under that scenario?
How did that tire temp compare? Heading West the right side tires were is the sun this time of the year??????
If the tires had a similar higher temperature on that side, I might not worry about it!
Servicing the bearings is the sure way to assure that you do not have a problem developing.
I have on the first on April(low 90's) seen higher tire temps on the shaded side(North side) between Phoenix and Palm springs when the wind was blowing out of the South all day at 40MPH. Hubs where not that far apart in temps!
Chris
