pigdoc's avatar
pigdoc
Temp difference between hubs
After I finished our 4 hour drive back home with our 2010 Cameo 32FWS I checked the temperature of each wheel/hub with infrared temp gauge. The two right side hubs were at 116F, while the two left side hubs were at 94F. Are these temps ok? Is the difference ok? I've not had experience in this area and I don't want a problem on our planned trip to Glacier NP from Iowa this July. Thanks in advance.
Pigdoc
  • The right side would normally run higher than the left due to the loading caused by the crown of the road. If the sun were also on the right side, that could explain the difference.
    Rusty
