stripit
May 30, 2013Explorer
I had the same issue so I just drilled a 3/8th hole into the receiver on the top of the receiver and used a tap to cut threads into the hole I drilled. Installed the biker rack, put a bolt into the hole I drilled and tapped and tightened the bolt. No slop or movement in the bike rack. Plus no way is anyone going to just pull the pin and remove my rack without removing the bolt. Total job took 10 minutes.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
