diazr2's avatar
diazr2
The little truck that could.
Just thought some of you would be interested in this. I got a new truck this year a 2018 F150 V8 6.5 bed club cab. 355 gears four wheel drive. 10 speed. I always pull my 5er with my F250 super duty but was always curious if my little truck would pull it and how hard it would be for the truck to do so. Well I set my F150 up to pull the 5er the other day and took it out for a test run. First place I went was to the scales. The truck is at it's maximum weight capacity. I thought well ok lets take her for a spin. I live on the Oregon coast so there is no flat spots to speak of just up one mountain and then down another.Too tell you the truth I was amazed at the trucks performance. I traveled up one steep long grade at 55 miles per hour it worked a little getting us up there but it was quite manageable. It was in tow haul it did not even shift too many times. Very impresive. Total weight it was pulling was 8000lbs The temp on the engine and transmission never changed. On the fifty mile spin I got 8 miles to the gallon. Total rear axial weight 3758lbs Like I said the truck was maxed out but you sure couldn't tell it by the way it handled. I had expected it to wine like a siren going up those hills but it still had more power to give if I had wanted it. Very impressive. Just to be crystal clear. I am not getting rid of my super duty. I was just surprised at how easily the little truck pulled the Fox Mountain.
  • The 150s have improved a lot in the last 5-7 years, and have great power. It appears you are under your RAWR, likely under tow rating (GCVWR). I see many of these type trucks, seemingly well over ratings, while towing a FW. Folks often times use what they got, seem to get by, not everyone can just trade up, even when they should. Nice that you have 2 trucks to choose from. :)
    Jerry
