davisenvy
May 11, 2016Explorer
WTP-GC wrote:
Let me see if I understand the OP correctly:
You currently have an Andersen UH, but you need the lower version. For $500, they offered to "convert" your existing hitch. Or they're offering to give you some trade-in value on your existing hitch.
If that's the case, then here's my take on it. You're going to be hard pressed to find a good used hitch for less than $400 to $500 on CL. You can buy a brand new "decent" hitch for that.
But really, your problem is that you're riding too high in the first place. The Andersen is basically designed to be approx the same height as a traditional 5er hitch. So if you buy another hitch, I expect that you're still going to have the same issue. I own a regular 5er hitch for my other TV, and even at its lowest position, it still sits higher than my lowered Andersen UH
If I understand your situation correctly, you either need to invest in the lower version of the Andersen UH or perform one of the various trailer-lift procedures.
I need the lower version instead of my current steel version. I will be trading in my current hitch and giving $500 to boot towards the new lower hitch making it a total purchase of close to $1,000.
I am aware that my FW nose is high and is why I am switching hitches.
Anderson Ultimate hitch is not designed to be the same height as a regular FW hitch. The 3225 and the 3220 are designed for a pickup truck bed with a gooseneck ball. The Andersens lowest setting is 16 1/8 in. Most FW hitches start off around 14 in. Also, the coupler that goes on the pin box adds another 7/8 inch. That's 3 inches higher.
I am more interested about the towing characteristics between the two. This is my first FW and I have never towed with a regular fifth wheel hitch. Thanks for your input though.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 20, 2026
