davisenvy
May 12, 2016Explorer
Me Again wrote:
So raise it on the springs first before spending money and see where you are at.
If you have a 20' board that is 5" off level, then raising the center of the board 2.5" will make level, assuming the high remains stationary.
Some people are installing the bolt on version of Correct Track, which raises the trailer.
http://www.lci1.com/correct-track-ii
Chris
There is a lower hole on my shackle for the leaf springs. If I drop to the lower hole it will raise my trailer 2". By doing this it might correct more than 2" out of the 5" that I'm trying to achieve?
I store my FW on a level concrete pad. I measured the skirt, front and back, and also check with an actual level. My measurements are withing .25" accurate.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 22, 2026
