The Hensley and PP hitches are great for Travel Trailers. They are designed to manage sway which is usually not a problem for TH's. Sway is primarily caused by low tongue weight. TH's are more ofte than not, tongue heavy unless you put a lot of weight in the garage. The toys balance the load. TH's are also heavier than TT's due to heavier framing/structural integrity due to the back door dropping down; it can't be used for support like on a TT. I have a couple of hitches; one being a weight distributing hitch; kind of a pain to use; especially with air bags, but they do work. I avoided a 5th wheel because I did not want the trade off of losing the use of my bed. My Talon is one of the biggest bumper pull TH's I've seen. Very heavy. The truck in my sig pulls it fine and it stops straight with brakes on all 3 axles. I haven't put two quads in my garage so I can't help you there, but I'm sure t hey would. My garage is a little bigger than most.
