Carl_n_Susan
Jul 10, 2016Nomad II
If you aren't already a member, join the Montana Owners Club (MOC) forum. It is free to join and has over 15,000 Montana owning members. Everything you ever wanted to know about Montanas can be found there.
Your Montana is heavy at around 16,000 lbs. The cheap Trailer King tires will not hold up on your rig. It is not a question of "IF" they will fail, the question is "WHEN". There are many, many stories on the MOC about tire failures and the resultant damages.
If you ignore the warnings and travel with your existing tires, be sure to keep the tire carcass after a failure. You will need it to submit to the manufacturer for any reimbursement they may offer.
About Fifth Wheel Group
